txnese
Jul 05, 2018Explorer
The chassis engine fires right up, so that battery is good. I checked the house batteries with a volt meter and it reads about 12.6 volts. I also checked the generator's starter relay, got 12 volts on input side, and 0 on the output side. I push to start the generator and the output side shows like 4 volts. I was thinking bad starter solenoid, so I used a starter jumper switch to give the output side 12 volts and nothing still happens. I would replace the starter itself, but the light on the button is dim. I almost want to blame the control board, but don't know enough to condemn it. I'll do some checking in the morning. Just doing what I can before I turn it over to an RV shop.
38,776 PostsLatest Activity: May 15, 2026
