ashlatz's avatar
ashlatz
onan Micro Quiet Generator
Hello looking for some help. Our generator will start and run with the circut breaker on the generator off. If the circuit breaker is turned on it will stop running or will not start at all. Any help will be greatly appreciated. We also had an issue with loosing power in the coach. The Generator would be running than for no reason we would loose power in the coach but the generator would still be running. The problem continued for awhile now we have the problem with the generator not running with the circuit breaker on. Not sure if the 2 are related or not. I can tell you than if I hook up another generator to the shore line everything works fine except the AC unit will not come on? Again any help would be great
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
