Sam_Spade
Jul 06, 2018Explorer
txnese wrote:
I push to start the generator and the output side shows like 4 volts.
Still assuming things that might not be true.
Do that again while measuring the input side of the solenoid.
The do it AGAIN while measuring the voltage at the battery.
Yes it is possible to drag the battery down to 6 V momentarily and then have it register 12 or more when the load is removed.
You STILL have not proved that the battery and connections are good.
38,776 PostsLatest Activity: May 15, 2026
