txnese
Jul 07, 2018Explorer
Battery was left to charge overnight. Tested fine with voltmeter, I also took it out to O'Reilly and have them tested the batteries. I have a voltmeter on the battery and voltage stays about 12v during starter. Tested on the input side of the starter solenoid and voltage is above 12v, this should show cable connection between battery terminal and solenoid is good. I tested the output side of the solenoid and get 12v with starter cable disconnected, with starter connected I get 8 volts. Bad starter? In the meantime, I'm double checking grounding cables.
38,776 PostsLatest Activity: May 14, 2026
