Sam_Spade
Jul 08, 2018Explorer
txnese wrote:
when I reconnect the cable to the starter, input side has 12 volts, output side has 8 volts. So either starter is bad and drawing too many amps or solenoid is bad.
IF....both of those measurements were made with the start button pushed, then the contacts in the solenoid are burnt. When the solenoid is closed, the voltage should be the same on both sides.....regardless of whatever else is happening.
38,776 PostsLatest Activity: May 15, 2026
