Son_of_Norway
Sep 15, 2014Explorer
As I recall, the top of the little box cap on the points is held in place by a small hex-head screw on the front, maybe one on the backside too. Use a small inspection mirror and a flashlight to be sure. Also have a magnet on your nut driver when you take it out. When I replaced the points on mine, my local John Deere dealer had them in stock. The part number is on the points. I think that you can upgrade to an electronic ignition but I haven't gotten around to it. The plug wire should go on a clip inside a rubber cap. Maybe you just pulled the wire end away from the clip. Good luck with your repairs.
Miles
Miles
38,782 PostsLatest Activity: Sep 10, 2026
