jmerritt
Sep 17, 2014Explorer
Brian,
Yes that little box on top of the generator is where you will find the points and condenser. I was able to install new points and condenser once I removed the air cleaner assembly and the heat tube that runs across the top. Depending on how close to the top of the compartment your genset is will pretty much dictate if you can get at them. You might check to see if your genset is one that will swing down for maintenance purposes. Look underneath to see if the genset tray is hinged. If it is then you are in luck. If not then you are looking at dropping the genset or fighting through the installation and adjustment.
John
John
38,782 PostsLatest Activity: Sep 10, 2026
