Argosy24 wrote:
FloridaRosebud wrote:
I tried that and bought an aftermarket pump for my 5500. It would not fit. Bolt holes would not line up, and there was no way to mod it to make it work. Bought the Onan and fit like it was supposed to.....buyer beware.....
Al
The important specs on a fuel pump are pressure and flow. Bolt holes can be drilled, 3 ft of gas line will probably let you relocate the pump anywhere in the generator compartment, maybe a short extension for the power wire.
It's not really a buyer beware situation, just a little innovation to save quite a bit of money.
Well, like I said in my post, there was no way to mod it to make it work. As an Engineer with over 41 years in the field, it would have been a serious jury-rig to make it work. It is VERY tight in my rig at the jenny. There was not enough metal on the mounting tabs to redrill. So I still think it's a buyer beware situation, as you have to really know your rig. That said, I kept the pump, because, if necessary, I could certainly do a temporary install if necessary to get me home (or wherever).
Al
