jyrostng
Oct 11, 2015Explorer
sometimes all you need to do is use a pencil eraser, turn off the pump, turn on a hydrant to relieve the pressure, pop the check valve ball built into the water connecter with the eraser and reseat it. It has a spring behind it and sometimes when you disconnect the water line, it won't reseat it's self correctly.
38,777 PostsLatest Activity: Jun 28, 2025
