mikestock wrote:
Lifetime fuel cost will be greater in the DP for two reasons. For some reason, I'll never understand, the cost of diesel fuel is greater. The second reason is that the DP will be on the road for more miles than the gas drinker.
Diesel fuel for many years was cheaper then gasoline, then it switched around to where diesel was more expensive then gasoline.
NOW diesel here in Barstow, Ca. is like forty cents a gallon cheaper then regular gasoline.
And you are correct when you post that diesel should be cheaper. Gasoline is a refined fuel compared to diesel.
