teacherjim69
Oct 17, 2014Explorer
i also have 2004 roadtrek, i was told that the compartment needed to be reinforced and the slide out tray installed which would cost several hundred dollars for the parts. I wanted to do the battery also, but it
sounded like more problems than it was worth. You also had to drill holes in the compartment with no templates available. I ended up changing to the led lights and new 12 volt tv. If you find it is easier to do please post how it went as I would like the second battery also.
38,766 PostsLatest Activity: Jan 10, 2026
