Usmcsousa's avatar
Usmcsousa
One thing After Another, Please help.
Alright, about a month ago my 95 Gulf stream (F53) Wouldn't turn over, After troubleshooting the systems with help from my friends here, it turned out to be a loose connection at the Starter. I Removed to old Connector , and replaced with a new non corroded one.
which brings me to Now..
Went out to the Coach today, started up, let her warm up for a few minutes. tried to put her in Drive From Park, No Dice!.
refuses to Shift while Running. Shut her down Turned my Key to the On Position and shifted to Neutral successfully. Started it up and Drove it to My house 1.5 Miles away to troubleshoot the issue.
Few Issues I noticed on the Short Drive home,
-Headlights will not turn on
-Radio wont turn on with the Radio switch on "chassis"
- Speedometer will not register speed, (remains at 0 mph)
-and the Big one, Engine Ran VERY hot on the Short drive, Fan was running. when I Stopped at home and shut her down, My "frigi Cool" unit in the engine bay started dumping about 1/2 a quart (estimate) of what appears to be Antifreeze from behind the Plastic Shroud that says "frigi cool" on it.
I am At a loss for words here, I have no Idea where to begin, No idea if these issues are related, and am affraid to drive it the 1.5 miles back to the Storage yard, but it cannot stay where it is now or My neighbors will Throw a frenzy.
Any Guidance in the right direction would be VERY MUCh appreciated.
Thank you all in advance
  • Since you replaced the connector on the starter, is this the first time you have driven it? If so, then look closely at the starter for any additional wires that may have been left off.
    I sounds like something electrical is not working.
    Just shooting blanks in the dark here.....
