CatchinBluegill
Jan 02, 2016Explorer
enblethen wrote:
Your problem is in your shore power cable.
Test each point for continuity before you tear them apart.
Problem is not in the rig.
Checked it. All points have continuity. I'll do some of the other tests as well, since even if I order a new cable today, it'll take a few days to arrive.
I also took resistance readings, low is 0.5 ohms, high is 0.7 ohms. That's comparable to a known-good three-prong computer power cable that I used as a control (low was 0.6, high was 0.8 for that cable).
Thanks,
Jonathan
38,768 PostsLatest Activity: Nov 21, 2015
