CA_Traveler
Jan 03, 2016Explorer III
enblethen wrote:X2
I would check your power readings either in the coach with all breakers turned off, or at the rig end of shore power cable.
Sure sounds like a neutral problem.
I believe he suggested that it might be a cockpit problem. But definitely worth checking again with no load and then with a load. I'd turn all electronic related CBs off and just use resistive loads like ceramic heaters.
38,768 PostsLatest Activity: Nov 21, 2015
