Dennis_M_M
Jan 31, 2015Explorer
You should have a rod about 4 feet long somewhere with a 90 degree hook on the end. On the rolled up awning, most likely the right end there will be a lever, usually T shaped. If it is up, flip it down, or vice versa. Then there should be the loop end of a strap hanging down somewhere along the length of the awning, grab that with the hook and pull the awning down. Then you extend the arms on each end to raise the outside of the awning.
The rod could be anywhere, on the floor in the closet, under the couch, in a compartment somewhere, etc.
