jspringator's avatar
jspringator
Opening behind mirror base 02 Winnebago Sightseer?
I discovered a little delam under my drivers side mirror. I removed the mild steel screws and replaced them all with stainless steel and a generous dollop of 3M4200. The delam appeared to get a little worse. I was wondering whether there is another opening behind the mirror base. If so I will have to either seal AROUND the mirror base or remove the mirror and seal the other opening.
1 Reply
  • my friends same year unit was far worst it was found found cap fiberglass around top were it was attached the main body sea-let was never kept up. Check you whole front nose cap and make sure is is seal well deal told told him him he never ever check the seal, right side fix was 4 grand.
