RVA_Jeff
Nov 09, 2014Explorer
Opinion on winterability of my rig
I have a Class C Coachmen Freelander 2006. The freshwater tank is actually in the platform of the bed (so in the heated area). What is exposed under my coach is:
-Black Tank
-Grey Tank
-Thick PVC pipe from one side of coach to the other, connecting gray water tank to the dump valver
-And then the dump valves themselves. I see no other exposed plumbing under the rig.
I don't plan to stay in this during zero degree temps, but I WOULD like to stay in it when the temp gets a few degrees below freezing -- say mid twenties.
From reading everywhere about this, I plan to:
1-Buy those tank heater pads that adhere to the bottom of the tanks for both black and grey tanks.
2-Wrap that grey water connecting pipe and as much of the dump valve system as I can with some kind of insulating sleeve.
I realize I could use RV antifreeze in the two tanks and keep adding to it, but that seems like a p.i.t.a. if I don't have to.
Does anyone think my idea is plausible? Any other/better recommendations? Advice much appreciated.
-Black Tank
-Grey Tank
