At first impression the Kountry Star looks nicer, however the Rexhall is a DP with an unloaded weight of 18,000 lbs. I don't see the weight of the gas MH but I would compare the HP of the 8.1 to its wt. and the HP of the DP maybe 300 hp to its weight. If a DP was important to you with this weight it might be a good overall MH for performance, fuel economy and cost. It is several thousand dollars cheaper and says make offer which says to me at least $5,000 cheaper and only a year older. I would look and drive both.
