pnichols
Dec 14, 2019Explorer II
docsouce wrote:
Just stopped searching after going through around 50 pages on our search, and searching the internet using "Best tires for a Class C RV"
Yesterday I called 3 major tire dealers in my Providence RI area. Also 1 in Boston. Seems Michelin has discontinued my original LTX MS2 tires and the Defender tires in the size 225/75R/16 and are no longer available in my area. After all this search time it seems (like a lot of other things) that the tires offered by the major manufacturers, Michelin, Goodyear, Cooper,etc and some of the foreign companies are just about the same. I don't like the aggressive thread on the Michelin Agilis which that company says is the replacement for these 2 and the RIB line doesn't work for me either. Right now I'm leaning toward the Goodyear Wangler Fortitude HT all Season. What do you guys use? I will be replacing all 6. I put 42,000 on the factory installed Michelins. My rig is a 2016 Freedom Elite 22E on a ford E350 Super Duty Chassis. We do mostly long distance runs so quite in very important.
Boy ... the Michelin Agilis CrossClimate tread and Michelin Defender LTX M/S tread sure "look" plenty close in design -> at least close enough such that I'll probably have the Agilis CrossClimate installed on our Class C when it's Defenders need to be replaced:
https://www.michelinman.com/tires/cross-climate/agilis-crossclimate.html
https://www.walmart.com/ip/Michelin-Defender-LTX-M-S-Highway-Tire-LT265-75R16-E-123-120R/175741498
38,782 PostsLatest Activity: Sep 10, 2026
