smlranger
Jan 18, 2016Explorer
aliceinanthemaz wrote:
Thanks for your input everyone. smlranger hit on why I'm looking for quality. He said regardless, be prepared to fix stuff. This I have learned for sure!
In my 24ft, I put on 50K miles in the last 5 years and it seemed like every cross country trip I took I always ended up fixing something. Maybe it was small or maybe something big, but I had to get used to taking things in stride. But I want to hedge my bets where I can. :)
So perhaps I should have also asked, when you do have to fix something on the ones you recommend, would you shy away from any of them because they tend to be more expensive than the others to repair?
That's not always easy to answer. The more complex the coach, the more expensive it will be to repair/replace stuff that breaks. For example, the more high end rigs may have Aqua Hot (hydronic) systems to heat water and provide heat vs. the LP furnace generally found on more mid line to low end coaches. A hydronic system is very nice but more expensive to repair or replace than a LP furnace. I had to replace the Webasto (burner motor assembly) on my Aqua Hot and a rebuilt unit was $1,800.
Obviously labor for repairs on any coach will be your biggest cost in many cases. So, the more you can do yourself, the more you save. Some folks are reluctant to buy orphan used coaches (the original Country Coach went bankrupt in 2010) and folks suggested I might not be able to get parts for my CC. However, now that Winnebago bought what remained of Country Coach, that may not be a big issue. Also, even on 'orphaned' coaches, many of the things installed on them are used by all manufacturers so you can still get those things.
The most important thing to consider if buying any used coach is to confirm if it has been properly maintained. Prior owner/s may be able to provide evidence of that but in many cases you must do your own homework/inspection, etc. to confirm it. You will be surprised how many folks spend big bucks for a coach and don't maintain them well.
