Rick_Jay
Aug 10, 2021Explorer II
BillyandKris wrote:
Will we be sorely disappointed in a gasoline engine or should we stick with diesel?
Will YOU be sorely disappointed? I suspect from the framing of your post that the answer to that is quite possibly "Yes". ;) Would I? Probably not.
It's a pretty subjective question that I believe only you can answer accurately.
As is often stated here and I concur, THE most important part of a motorhome is the floor plan. Find a floor plan which your wife find livable, both on the road and while parked. Well, mostly your wife...but it's OK if you like it too! LOL :)
Also make sure that it is on a chassis that can carry the intended weight and have adequate tow capacity without exceeding the manufacturer's ratings. If you can find all of that AND get the diesel and it is within your price range, then go for it.
But if finances require that you are given a choice between a gasser with the ideal floor plan and a diesel with a less than optimum floor plan, I'd take the ideal floor plan with a gasser.
Good Luck in your search,
~Rick
38,780 PostsLatest Activity: Aug 05, 2026
