Put plenty of water in first. 3-5 gals. Do you have a tank flush in your wet bay? If so, use it to finish filling the tank. Once it reaches full and the wife yells it out the window to you), leave it on when you pull the black valve and wait ffor the water to get clear. Close the black valve and let the flush run for a couple minutes to add water for the next trip.
At the end of the season, after the last dump, I use calgon liquid water softener to clean the tank. I add 6 OZ and fill the tank with the flush. This helps free deposits and clean the tank.
