JetAonly wrote:
thgoodman wrote:
Just wondering.... did you check the load on the rear axel. That thing is cantilevered out pretty far and most MH without a tag are marginally over loaded anyway. You may want to get your rig weighed fully loaded. I would think you would have to, at least, increase tire pressures to handle the additional load or maybe even go to higher load rating tires.
FWIW It looks like 33200 is the GVW. Single axle on mine is rated at 20k to comply with federal guide lines, although a few have been rated at 23k. Good news is mine is really a 34k axle per the manufacturer. I not surprised that it was difficult to install, CC did not design it that way. Short DP's are prone to handling issues anyway and 1000 more pounds might really wag the dog. Alas, the money is spent, no changing things now.
I wasn't thinking so much of the axle's carrying capacity but the load rating on your read tires. Increasing the tire pressures will increase the load carrying capacity of the tires up to a point then you may have to think of going to a higher load rating tire. Also, since your 1000# load is not over your rear axle, the cantilever will considerably increase the load your rear axle sees.
