anav8or
Oct 23, 2014Explorer
Outside "Entertainment Center" 120v Outlet Issue
We have a 2006 Four Winds Chateau 31F which has an outside "Entertainment Center" containing a 12v outlet, 12v stereo, and a 120v outlet. At a tailgate a few weekends ago, the 120v outlet stopped working. The outlet has a GFI sticker on it and the RV has a single GFI circuit that runs to the bathroom and kitchen and appears to terminate at the water heater. I can access the back side of the entertainment center under the jackknife couch and can see where the wire feeding the outlet goes into the floor. I can't see where it goes from there.
So...I checked all of the outlets in the bathroom and kitchen - all have power and the connections are good all the way to the water heater. I tried replacing the outdoor outlet thinking there might be a fuse in there - no dice.
I contacted Thor and asked for a wiring diagram for the coach. They provided a doc that shows where all of the outlets are but not how they are connected - not real helpful.
Has anyone run into a similar issue and, if so, how did you resolve it? I'm a my wits end trying to figure this one out. Thanks in advance for any advice you can provide.
