FIRE UP wrote:
Scott & Jill wrote:
I have a workhorse chaise with the big block 454 engine I have replaced the clutch fan and flushed the radiator but the engine keeps going into the red dose anyone have this problem and if so do you know a way to get it to stay cool any suggestions would be appreciated.
Thank You
Well,
You've done some measures to alleviate this issue but, apparently they've not worked so far. As has been suggested, I'd check the thermostat and, since water pumps CAN GO BAD, I'd verify that yours is working proficiently. You can do this by, starting with a cold engine, and the radiator cap OFF. As the engine is started, no coolant will flow, during the warmup process.
Then, if your thermostat is working correctly, it will open at a predesignated temp, usually around 180 or up, depending on what's called for in the specs. When it opens, you'll see a rush of coolant zoom by the opening in the radiator. That is an indication that your water pump is pumping the water/coolant, through the system.
Then not too long after that coolant begins to flow, it shuts down pretty much completely. The reason is, the cold coolant that was sitting in the radiator, that is now beginning to flow into the engine, triggers the thermostat to close.
This is all presupposing that your T-stat is opening and closing, not only on time and, at the appropriate temp but, is FULLY OPENING TOO. I've seen them barely crack open and, that's a really restricted flow.
One more thing. About 99.9999% of the bottom radiator hoses come with internal springs in them. In case you don't know what the spring is for, it's wound around the inside of the hose, to keep the hose from collapsing when suction from the water pump, is pumping the coolant through the engine and radiator.
If that hose deteriorates to a point that, it allows the hose to collapse, that will severely restrict the coolant flow which, in tern will cause higher engine temps.
I've seen many times, that spring IS GONE due to corrosion and rust. it doesn't happen all that often in todays engines because of improvements in coolant chemical makeup and, improved milage for coolant. But, never the less, it's something to check and make sure it's working correctly. Good luck.
Scott
Thank you for the Information it will be helpful.
