Scott___Jill's avatar
Scott___Jill
Over heating
I have a 1996 Fleetwood class A with the Chevy big block engine It is over heating. I know that the fan was replaced with a flex fan I'm not sure if the fan clutch was replaced but dose anyone know what fan and clutch needs to be in there?
  • Kayteg1 wrote:
    Let's wait for new member starting a topic " I just bought this motorhome and it is overheating"
    They know of the problem and is going to fix it before they sell it.
  • Let's wait for new member starting a topic " I just bought this motorhome and it is overheating"
  • Scott & Jill wrote:
    Thank Every one for the input I solved the problem I traded it in on a newer coach.
    And now have a new set of problems.
  • Thank Every one for the input I solved the problem I traded it in on a newer coach.
  • Not only fan, but might check for flow on the rad itself.. Also, might have a minor blown head gasket, or any number of other things for a rig of that age.. ;)
    It is best to try the easy and cheap stuff first, so looking at the coolant condition and change out the Tstat is first on the list of course..
    Good luck!
    Mitch
  • X-3 for the fan clutch. That would be my first guess for the problem. Second would be a bad thermostat. I would check the thermostat first since it's easier to do.
  • I kept the steel fan blades and installed the Hayden Severe Duty Fan Clutch.The flex type blades work against you as they are designed to flatten-out at high RPM for fuel economy and not cooling.
  • If the flex fan has fiber glass blades, it probably not up to the job. If the fan is one of GM's old 7 bladed, metal flex fans, it's probably up to the job and you need to look else where for your problem. The fiber glass fans will have a high pitched zing. The metal flex fans with have more of a roar. Either way, a clutched fan is the best of both worlds as far as cooling and noise.
    Richard
