want-a-be wrote:
We are in need of a over the air antenna that is not directional since we have no way to turn it. We have tryed a Rayzar RZ 8535 and only got 4 stations.
People in the park with batwing antennas or getting 30 plus stations, I know they pick up better but there should be a antenna that picks up more then 4 stations without putting a hole though the roof.
Thanks for all comments
Well according to your owners Manuel on page 4-6 you can move your antenna.
Television Antenna You can automatically search for channels that are active in your area by editing and scanning channels on your remote control. To do this you will need to:
? Press the power button to turn TV on
? Press Menu
? Go to Setup, press “OK”
? Go to Ant/Cable Setup, press “OK”
? Make sure ANT IN is on Antenna to program Antenna or on Cable to program cable
? Then press “OK” on all channels
? When scanning is complete, press “OK”
NOTE: The booster must be on for ANT (green light will appear) and off for the cable. The booster is located in the front, right cabinet of your unit.
If you do not receive the desired channels, re-direct the Antenna with Control located in the upper cabinet in front of the passenger seat. After re-directing the antenna, you must rescan channels.
Bill
