D_E_Bishop
Apr 20, 2019Explorer
I would really like to know a little more about what the OP has as far as the BOMB, splitters, antenna, and where things are located. I agree that the first and fastest thing to check are all of the connectors for tightness and that they are connected to the correct point.
Then, he should swap the cables for the two TVs. If the problem follows the cable. Problem solved, it is somewhere in the cable for the front TV.
That is pretty easy to trouble shoot. In most RVs all the external equipment is located in one spot and isolating each piece of equipment is in general very easy.
Without knowing about the attached equipment, how do you know where to start. What I have recommended would work for my rig, I have the Winegard Pro, a bomb and Sensar 4 antenna.
38,782 PostsLatest Activity: Sep 10, 2026
