Dale_Traveling
Sep 27, 2016Explorer II
Moving items forward will help, a lot. Had my coach checked a few weeks ago and found I was 140 lbs over on the rear axle but plenty of capacity remaining on the front. Moved a heavy two burner Camp Chef Grill and associated accessories from the very ear of the coach about 10' behind the rear axle to storage compartments directly behind the front axles. Dropping my potable water load from 50 gallons to 20 gallons also helped considering the tank is in the very back also. Added a couple of cases of bottles water up front to compensate for less in the tank. Lost 780 pounds off the rear and gained 260 pounds on the front.
Watch the loading and distribution of the trailer weight. Not exactly sure what the dynamics are but somehow its critical to stability of the trailer while going down the road.
