BigGuy82
Apr 06, 2015Explorer
okhmbldr wrote:
I don't think I noticed anything about the tongue weight capacity for the hitch.
If you have a 5000# hitch, then the tongue weight will be about 500#, 10,000# hitch, then TW of about 1000#, maybe more, just check the specs from the hitch manufacturer. If your tongue weight limit was 1000#, then I think I would rethink adding 1600+# on the rear.
Doesn't go on the original hitch. That one is replaced by a hitch with 3 2" receivers - one in the center and two on either side of it - about a foot out from center. These are welded to the frame. The lift rides on the two outside receivers.
