John_S_
Apr 07, 2015Explorer II
I think you will be overloaded with the lift on. Can you do, sure you can. Would I do it, no. I looked and did the numbers and got a smaller bike and a versa haul ramp. Much lighter setup. You are stressing your unit and if you are only rated for 5000 pounds towing your frame setup is not going to hold a 1000 pounds tongue weight. It is your coach, so do as you wish but it is too small a coach to put the big bike on the rear.
38,782 PostsLatest Activity: Sep 10, 2026
