Ivylog
Apr 07, 2015Explorer III
Towing the F150 will not put any tongue weight on the hitch so that 500 lb rating is a non issue. Because in Stopping/Starting you will be putting more forward/backwards on the hitch than it's rated for... I would add a pair of braces from the center receiver to the MH's rails aprox 4' in front of where the hitch fastens to the rails. These braces will look like a V (from the rear) and I would use 2" angle iron for them. They will transfer most of the forces to the rails without exceeding the hitch's rating. With a good brake system for the PU and the bike on a loading system like Fire UP uses I think you will be much happier. Also in the back of the PU the bike is going to stay cleaner.
You will also not be using up a lot of your Cargo Carrying Capacity of the MH which could be as low as 2000 lbs... should be posted behind a cabinet in it or ask the dealer. CCC is how much of your stuff you can add with the MH full of fuel and water and people.
38,782 PostsLatest Activity: Sep 10, 2026
