sullivanclan
Jan 30, 2019Explorer
Overdrive Button Stuck in Off on 2003 Ford 450 Class C
First I had a button that wouldn't turn the overdrive on or off nor would the light go on. So after some research about bad wires, I replaced the shifter that the overdrive button is connected to. Now the overdrive is off all the time and the button doesn't work, but the light comes on and stays on. I have had a mechanic look at it, but so far he was puzzled, maybe a short. When he hooked up the old shift lever, it began to work ok.
Before I get back into the ignition and replace shift levers back to the old one, has anybody had similar experiences? Suggestions? If it is a ground, where might I find that?
Transmission seems to work well and shifts smoothly. Has 56,000 miles.
Thanks!
Thanks!
