wolfe10
Nov 11, 2013Explorer
ScottG wrote:
By 240 the fan should have been engaged. They make quite a roar so if you don't hear it then that's probably the issue. If it's the clutch type make sure you get genuine a Cummins part. There are much cheaper alternatives but they just don't work right.
A fan clutch has been mentioned by several. I would be quite surprised if this chassis even has a fan clutch. Suspect (strongly) that the fan is BOLTED to the pulley-- no clutch at all.
Easy to tell. When looking at the CAC, suspect you will see bolts securing the fan directly to the pulley.
38,782 PostsLatest Activity: Aug 31, 2026
