OhhWell wrote:
Daveinet wrote:
Executive wrote:
Sounds like a lot of folks on here know more about towing and laws of physics than any of them dumb old engineers anyway, so go for it. If you're stopped or have an accident, just tell 'em the guys on RV.net said it was ok....that should work......Dennis
The difference between the "dumb" engineers and the laws of physics is that the laws of physics are not governed by marketing. In other words, no RV manufacturer is going to bother listing the 20 different ways you can tow something, and specify a different weight rating for each method, even though if one were to do a complete analysis, several different weight limitations could be legitimately published. They publish a one size fits all, to avoid confusion.
Thank you for posting that. I was trying to put my thoughts into words but you pretty much nailed it. If a good engineer had actually been tasked with designing the capacities sticker on a hitch he or she designed, it probably wouldn't even fit on the hitch. :B
And you guys are SO much more qualified to make that kind of decision. Sort of like the OP saying he put 2500 lbs of material in a truck rated for 1000 lbs and thinking that just because the truck didn't fall apart this time it must have been ok. Original engineer must have been wrong!
