phil-t wrote:
If you build aroute in TripWizard and import it in BasCamp (BaseCamp will do the changing, given the vehicle profile you have there). I have never seen my Garmin 770 change the route I built in BaseCamp. Careful when you do the work in BasCamp that you are consistent in the profile you choose, and use.
When a route is downloaded from Base Camp into my Garmin GPS I've noticed when I select that route in the GPS, the GPS starts "calculating" a route to your destination. This means to me that a new route is created, but like you said above as long as the profiles are exactly the same and Base Camp and the GPS are using exactly the same maps then the routes should be the same. But since the route downloaded is calculated by the GPS it is not really the route you downloaded even though as mentioned above it may be the same.
