Bill_Carry's avatar
Bill_Carry
P-30 Brake Squeal
My 1994 P30 chassis M/H has always been fussy regarding brake squeal. I bought this M/H new and have over 220,000 miles on it. Found from experience that only Delco (GM) pads would not squeal. Now have a bad squeal from L/R brake coming to stop. Six months ago the pads,rotors, calipers and hoses were replaced in the rear by a very reputable truck shop (I'm getting to creaky to do this stuff myself like I always used to). Recently this bad squeal developed. The shop that did the work last spring replaced the rear pads again. They didn't find anything on the L/R brake suspicious. The squeak is reduced, but still happens. It takes a half hour of stop and go driving to get things hot enough for the noise to occur when coming to a stop.
Any thoughts or experiences that might help would sure be appreciated.
  • One thing that you could try, if it has not been done. They make a lubricant that goes on the back side of the pads between the caliper piston and the out side where the outer pad sits. I have know this to help with a squealing sound.
  • Another issue I had, was not the proper lube used on the slide locations on the calipers.
  • I would be interested in knowing the temperature of the rotors between the two sides since you say the squeal starts after it has had time to heat up.
  • Yes, the hoses were replaced as well as the pads,rotors, calipers, fluid, etc.
  • Have the rubber lines been replaced? I had restrictions that caused squealing. It was on the front.
    Many companies making pads have changed their formula for the pads. I have only used ceramic pads. The organic and semi-metallics would not last.
    Have they flushed the fluid?
    Were the rotors turned? If they replaced the rotors were they checked for warpage?
