Gjac's avatar
Gjac
Explorer III
Aug 24, 2017
P-30 front end parts
I posted in July about how my RH lwr ball joint suddenly failed while rounding a LH curve and the whole front end just dropped causing the tire to blow and the floor to be pushed up. I suspect that that the shop that rebuilt the front end 2 years ago put the wrong part in. I have read on here that pick up ball joints have been mistakenly installed. Does anyone know the right part numbers for the lwr ball joints and lwr control arms for a p-30 chassis. Also do heavier P-30's require a heavier duty ball joint and lwr a arm that the smaller chassis? MH is still in Mt. waiting to be repaired?
  • Gary missed your call. Didn't want to call you this late.
    I found this in my P30 stuff.
    I would make some calls also.
    With 4 wheel disc Moog #
    Upper K6174
    Lower K6511
    With rear drum
    Upper K6122
    Lower K6129
  • Call a NAPA Truck parts place. Not the local NAPA but one that does truck parts. The one I found nearest to you is 757 1st Ave, West Haven, CT 06516 (203) 937-2266
    I have never got the wrong part for my P30 from a NAPA Truck place.
    You should have the VIN
