mike_brez's avatar
mike_brez
P30 caliper removal
Looking to change front pads. I have ran into a caliper I never worked on. The manual I have says its a Bendix. Their is no slide pins or caliper bolts. The only thing on removal I was able to find was that there is a key support that you tap out that has a spring and rattle clip. Any help would be appreciated.
  • Look on lower portion of caliper.
    There should be a set screw that inhibits the key from moving.
    Unscrew the set screw until it clears the u-shaped wedge. Then tap out wedge. Use a punch or drift so as to not damage the wedge.
  • 352's avatar
    352
    Explorer II
    I think you should take a better look.
