Rog___Nan's avatar
Rog___Nan
P30 chassis
Have a '96 Georgie Boy Cruise Master on a Chevy 454 P30 chassis. DH thinks we are having a problem with the fuel pump. I did a search but most of the topics are not specific enough for him! Anyway if you have this particular chassis and have replaced or worked on the fuel pump, he would like to know about where you cut the hole in floor to access the fuel pump. (I don't like the thought of him cutting and cutting just to find the pump.) He doesn't want to drop the tank as it's as you know OLD and probably rusted bolts etc. just don't want another problem to pop up. We have a schematic of the frame with location of tanks etc. from the original GBM flier when we purchased unit in '96. He thinks it is just very generic. The unit is cranking too long to start, runs great once on the road, have had the relays checked they are good. Thanks for any help you can give us.
  • RLS7201 wrote:
    If those rear storage compartments are pass through, cutting a hole in the floor will only get you into the storage compartment.
    Richard
    I bet a cold one that his gas coach doesn't have a pass through compartment.
    Bill
  • It might be the fuel pump but if it runs good on the road under load then I would look elsewhere first. Check the hoses for leaks/cracks that could let air in and fuel to drain back. Filters, but they would cause problems under load if bad. It is hard to do long distance problem solving.
    Bill
  • If those rear storage compartments are pass through, cutting a hole in the floor will only get you into the storage compartment.
    Richard
  • If it runs good when on the road, I would think the pump is good. I would be looking at the tune up part, filters , air and gas, plugs and wires, distributor cap and rotor.
    Is it hard to start hot and cold. If injected do a leak down on them.
