Stuck_in_first's avatar
Sep 01, 2013
p30 front caliper removal
Need to remove the front calipers on a chevy/workhorse 2000 p30 chassis. removed the set screw so now what do I do. Is there a plate holding the caliper on. Do I have to remove it? If so how? Or does the caliper just rotate up?
  • I have worked on brake systems for over 30 years and never had a failure. I just have never run into this configuration before. The reason i ask is so I get it right because I am careful. Thanks for your helpful answer.
