mike_brez's avatar
mike_brez
P30 wheel bearings
Has anyone changed their p30 front wheel bearings. I have a little play with front end off the ground and hold the tire at 6&12. Pushing at 6 and pullin at 12 and visa versa. This may be the problem to my Moho wandering.
  • The wheel bearings should last for 100,000 plus miles. they should be lubed according to manufactures specs, but they rarely go bad.. With the wheel in the air, remove the center dust cap and pull the cotter pin and the nut lock. Turn the tire slowly and snug the wheel bearing nut with a pair of channelock pliers. If the movement is still there you have play in the ball joints..
