1969SSCamaro
Mar 12, 2014Explorer
P32 New Coil Springs Too Much?
Hello All,
I am new to Class A MH ownership and want to thank everyone who runs and participates in this forum. I have spent untold hours researching forums and the amount of information and detail is greatly appreciated. My learning curve has literally been accelerated by years as I am able to understand common problems and weaknesses of the P32 chassis; so thank you very much!
A couple of months ago my wife and I purchased a 27’ 1995 Georgie Boy Pursuit with 37,000 miles. It has 454 TBI engine with front disc brakes and rear drum. The GVWR is 12,300, front GAWR is 4,880, rear GAWR is 10,000. Initial measured weights (me, wife, daughter, but no supplies, minimal fuel, water, etc) with 2,360lb horse trailer (no horse) in tow are: Front = 4,220, RV total = 11,800, RV+ trailer = 14,200. The chassis is 159” wheelbase; P31432.
Last week I completed the installation of Moog lower ball joints, new brake pads, brake bleed and Stengel Bros coil springs (PN 350-6560SD). The springs are rated at 3789 lbs each. I made a Guestimate that the stock springs were rated at 2789 lbs (??) and purchased these springs hoping to get rid of the airbags and gain an inch or two in lift. I ended up with a little over 3” of lift and now concerned that these springs are too much and will have to be replaced with 3289lb springs instead. My current/wishful thinking is to continue with rear end work/inspection/measurements and once complete, load her up for real; right now my wife has gutted the inside for renovation, so it will be a while before I can test drive it. I measured the suspension clearances after the new coils were installed and have RR = 4-1/8” , LR=4-1/2”, RF = 5-1/8”, LF = 5-1/4”. The chassis/frame currently sets about dead level, but it is not loaded at all, not to mention the horse trailer. Per the “P Chassis for Motorhomes General Information for Alignment, 5” is the max height listed in the table to determine proper caster. Am I dreaming that the 5+” of height could be okay? Comments, advice and experience welcome…………………
For reference, work completed to date includes; new oil, water and trans temp gauges, hitch reinforcement, trailer connector and wiring, front/rear sway bar bushings, Dale deep trans pan, radiator flush, SS bell crank, steering damper, brake pads, repack wheel bearings, thermostat and hoses. Work still planned includes; oil change, inspect spark plugs/wires, new master cylinder (mine is pile of rust)/fluid flush, rear brakes, brake controller installation, rear-end fluid change, shackle bushings, drum brake job, power steering fluid change and finally front-end alignment.
Thanks, Greg
Thanks, Greg
