mexicanpiloto13's avatar
mexicanpiloto13
Explorer III
Aug 29, 2016
Pac Brake pops out of second gear for an instant
We have a Monaco dynasty 1998 with An Allison world transmission and pac brake. About a month ago, the pac brake failed. we thought it was the pedal but when I took it in to Freightliner, it was a relay they replaced. it worked fine on the flats, but on vacation now, on the big hills, we've noticed the pad brake pops out when activated. it'll drop down to second gear right away and then it'll pop out and release the paycheck brake, and go back and pop out over and over again. The transmission indicator shows it flipping from 2 to 6 back to 2 to 6. other than that, it works fine I'm wondering what might be causing that little glitch. it's almost as if I'm going too fast for the gear but I've slowed down and it still will blip out back and forth. Thank you
  • you may have a ecm programing issue if the minimum engine brake speed is set too high it will disengage at the speed it is set at and then reengage when the coach speeds back up. this parameter can be checked and reset at any cummins shop
  • wolfe10 wrote:
    No if you were in danger of overspeeding, the Allison shift pad would NOT go back to 6th.
    You have an electrical problem between before the Allison ECM. Fuse sounds like it is still good as it does work at times. Switch may be an issue, relay may be an issue, connection to Allison ECM may be an issue.
    X2
  • No if you were in danger of overspeeding, the Allison shift pad would NOT go back to 6th.
