3sacrwd's avatar
3sacrwd
Pack Rat?
Went to the storage yard this week, and found that something had been in my AC units INSIDE the coach making two nests. There were leaves, and these little pumpkin looking berries, about the size of walnuts. There had to be at least 30 of them in the grill of the AC unit. There was also rat poop all over inside, as well as pieces of the styrofoam insulation. There was at least 2-3" in the slide portion of the quick chill vent. I checked the AC units up on the roofs, and could not see ANY evidence of it getting in that way. Both were very clean, with only a hint of any poop. How else can they get into the AC area and the ceiling ducting. I didn't see any other evidence behind the fridge, or anywhere on the engine, etc. Nothing else at all in terms of where they could have gotten in. I am stumped. I also did not know that the two ac units shared a common ductwork. It somehow traveled from the bedroom to the living room, or vice versa. Weird.
  • After you get things cleaned out,stuff steel wool in every hole that you find,then put dryer sheets in your side bays,or Cab Fresh in your side compartments,and under the bed and thur out the coach, I refresh every 4 months,
  • Rats can get in a hole no bigger than your thumb. They are like contortionists.
