S-n-L
Jun 19, 2013Explorer
Pad under jacks
Hi all, Does anyone use pads under their jacks to prevent damage to the surface under the jacks or to prevent the jacks from sinking into soft ground? Has anyone used this brand of pads: http://...
hammer21661 wrote:
I usually use a 6x8 about 14 to 18" long if I am worried about sinking I place it on a pair of 2x8s or 3x 8s about 14 to 18" inches long. I lay them down next to one another and cross with the 6x8. They will not sink unless you are camping in a marsh. If height isn't an issue I would probably use an 18" 3x10 under each pad two with a cross piece the same dimention if I was worried with your rig. The out rigger pads are pretty expensive aren't they? I also Use a short boat hook about 3 or 4 foot,it works wonders for reaching things.
