timmac
Feb 07, 2017Explorer
Treefrog wrote:creeper wrote:
Put a good synthetic wax on it. Easy to put on. Reapply every six months if the sun is that bad. The only reason it's cracking is because of the lack of wax and the clear coat is cracking. You could have it wet sanded and clear coated again.
My 2000 Country Coach clear coat is peeling. A vendor recommended wet sanding all the white colored panels in the effected area but wanted $ 10,000 (So. Calif.).
Does anybody have a fix for a couple of areas totaling 200 square feet?
The only fix is wet sanding the clear coat off and reapplying a new clear coat, it can be done yourself outside if your handy and have the right tools to do it correct, most any body shop will charge a lot of $$ to do the work, maybe find someone south of the border to do it at 1/2 the cost, however I will tell you its best to do the whole RV with new clear coat because the other areas will be doing the same as time goes by.
38,782 PostsLatest Activity: Sep 10, 2026
