et2
Jun 15, 2014Explorer
Painting under MH
I'm considering painting under the MH to prevent rust ( and fix what rust is there). So for those who have done this, what support have you used after the MH is raised to prevent it from coming back d...
timmac wrote:et2 wrote:
I'm considering painting under the MH to prevent rust ( and fix what rust is there). So for those who have done this, what support have you used after the MH is raised to prevent it from coming back down while under it.? .
As to your sig you have a Fleetwood diesel motorhome, just raise the air bags and support frame with jack stands, no need to raise any higher, should be able to slide right under and spray away..
