93mastercraft
May 05, 2014Explorer II
Effy wrote:93mastercraft wrote:
IMHO, The Palazzo has more than it's fair share of issues.
How is the 35.1 treating you once you got the leak fixed?
Found an engine coolant leak over the weekend. Tightening one of the transmission cooler hoses hopefully fixed that. Can't really blame Thor for that one, unless they had to remove hoses in the rear to install other parts.
I also found a poorly installed slide roller on the bedroom slide. The roller was held in with only a couple of screws that were splitting the plywood on the bed base. I reinstalled it properly by adjusting it over some where I could install the two screws they used into new holes and then I installed 6 more screws in all the holes already provided in the roller mounting plate.:S
38,770 PostsLatest Activity: Apr 12, 2026
