booster
Oct 23, 2013Explorer
senf wrote:
We dry camped for 3 days this summer and the chassis battery wouldn't start the engine at 9+ volts. The separator was not wired to allow coach batteries to assist in starting. On returning home, we had the separator checked - not charging the coach batteries. Probably discharging the chassis battery. New separator installed and wired for manual assist from coach batteries. Sorry to hear from Booster that we have an on going problem. However, we will conduct an experiment by not connecting shore power to the RV and see what happens.
If by manual assist from coach batteries means using the coach batteries to start, Ii is not a good idea on a Roadtrek. The front to rear wiring is too small, and there are several 80 amp (50 on older ones) breakers in the line. You could use the assist to charge the starter a bit, as the the dead battery will take some charge from the charged ones, but I wouldn't try to start off the coach batteries.
38,766 PostsLatest Activity: Jan 10, 2026
